Cv joint retaining clip
Hi,
I need the small retaining clip that holds outer cv joint on the original was bent beyond repair and I managed to brake the one that came with kit.
Anyone know where I can get one or know the correct size
The small one that goes around the driveshaft end of the outer boot? In my experience, a cable tie is fine. In fact, I prefer one because if the boot needs to slip a bit of any reason (hopping a kerb in a full lock for example), I'd rather the driveshaft end slips than the CV end pops off.
If you really want to put a metal clip on, you can get assorted packs from a motor factors or ebay for not a lot. Doesn't matter if they're over length as long as there's a pin to bit onto, you can always cut the excess off.
No it holds the cv joint on the drive shaft it clips onto the shaft then you push the cv joint over it and it springs back out
Look on ebay for "CV joint snap ring"
Not sure of the size but 27mm seems to be common for a lot of the Citroen / Peugeot models.
(29-07-2023, 05:44 AM)Chriz1 Wrote:  No it holds the cv joint on the drive shaft it clips  onto the shaft then you push the cv joint over it and it springs back out
Is the part number on catcar.info?
http://www.catcar.info/citroen/?lang=en
If not, @jj9 is probably correct, IIRC the shafts are 29mm dia so 27mm would be about right.
Electric parking brake recall
Yesterday 11:21 PM
Syphoning fuel from the tank
Last Post: Gryffindor
Yesterday 10:38 PM
Tailgate Insulation
Yesterday 10:34 PM
Stop start issue
Last Post: Zion
Yesterday 07:54 PM
plug and program accessories?
Last Post: Zion
Yesterday 07:48 PM
BSI
Last Post: Zion
Yesterday 06:13 PM
» Replies: 35
Dropped a valve ?
Yesterday 02:35 PM
» Replies: 26
2.0HDI juddering solved
Last Post: Zion
Yesterday 06:32 AM
» Replies: 16
Suspension ans wheel tuning for motorway trip
Last Post: jamesburden19
Yesterday 05:35 AM
» Replies: 27
Replacing wings
Last Post: Sparkerboy
01-10-2023 04:36 PM
