Poll: Berlingo B9 Wiper Control Arm
You do not have permission to vote in this poll.
Repair
0%
0 0%
Replace
0%
0 0%
Total 0 vote(s) 0%
* You voted for this item. [Show Results]
B9 Enterprise van wiper control arm
Hi everyone,
My name is Seamus and I live in France not far from Saumur. I bought my RHD Berlingo Enterprise new in Jersey C.I. December 2010. To date it has done about 74,000km or about 45,000 miles. It has given no trouble and the only things changed have been tyres, brake pads and a new battery. The a/c works fine and has never been re-charged. I moved to France at the end of 2018. It did about 2,500 miles a year in Jersey all start and stop stuff below 40mph. Since moving to France, my usage has increased and it seems to go better with trips to Spain, Portugal and Ireland.
The first issue manifested itself in a heatwave last year. The left indicator would not work in high temperatures. If the weather is very hot the left indicator will play up most of the time. In cold weather, it never malfuntions.
The second issue was last week. I have a habit of frequently using the button that shows fuel consumption and is used to reset the use of the inbuilt information system in PSA cars. It is on the wiper control arm. Last week, it went a bit crazy and set off the rear wiper wash mechanism and drained the reservoir. I took the cover off the rear wiper motor on the back door and disconnected it. If I touch the said button on the wiper control arm, it straight away sends a jet of wiper fluid down the back window.
This Berlingo of mine is now coming up to 13 years old. I think it is time to also change the timing belt. I check it visually every month and I cannot see any visual deterioration. The mileage is still low but I do hear of horror stories.
I am not a mechanic. I think the 1st and 2nd issues are connected. However, I think the controls in the steering wheel mechanism are awol and needs fixing or replacing. I write this short note to see if you oracles of knowledge on this forum might have some experience of this issue.
Have any you forum members had this issue with a B9 or with the sister PSA cars/vans that use the same steering wheel control arms?
Once I have an idea what I am dealing with, I will make decisions on getting the work done. Stripping the steering wheel leaves me uncomfortable.
I fully intend to keep this B9 for another good few years.
Seamus
Be worth checking bulbs for corrosion and replace, to rule that out. Weird things uncontrolled worth resetting the business well documented on here. Always a good idea if available to use diag box also well documented on here to see if you have any fault codes to give you a clue.
That should be BSI not business . Spell checker got me.
Probably the Comm2000 board under the steering wheel is faulty, or as OMG says, do a BSI reset. Search the forum, I posted the process at the top of the "how to"s section in pink.
(30-07-2023, 08:56 PM)OMG Wrote:  That should be BSI not business . Spell checker got me.
Hi OMG,
Many thanks.
What is a BSI and do I need to buy a diagnostic unit ?
Seamus
(30-07-2023, 08:58 PM)Zion Wrote:  Probably the Comm2000 board under the steering wheel is faulty, or as OMG says, do a BSI reset. Search the forum, I posted the process at the top of the "how to"s section in pink.
Hi,
Thank you.
I will take my Berlingo to one of the smaller garages here in small town France. I see one of them does everything from a 2CV to modern stuff. Maybe get this done and then the timing belt, water pump and other this electric/electronic stuff.
Seamus
Just search on here for BSI and diag box and you can learn all about it.
I'd check the stalk internals. It can be popped open. Start by prying the end button. I believe the rotating section reveals small parts so better to open it in plastic bag for not to loose any.
If the original cannot be salvaged, new individual stalks are available at Aliexpress or Ebay. Before buying, you need to remove steering wheel and/or column coverd to check which kind of stalk you need to select from different available.
Edit: oh yes, ofc first check with Diagbox which commands the Com2000 sends when using the stalk button and barrel.
BSI
Last Post: Zion
Yesterday 06:47 PM
» Replies: 26
Dropped a valve ?
Last Post: james1089
Yesterday 05:34 PM
» Replies: 24
HELPPPPPPP, citroen extended warranty team rejec...
Yesterday 05:20 PM
Add blue / engine fault light
Yesterday 05:13 PM
Newbie
Last Post: Rosemerry
Yesterday 02:48 PM
Electric probs - where to start
Last Post: Zion
Yesterday 10:58 AM
Replacing wings
Yesterday 10:01 AM
Sliding door rattle
Last Post: melpa
Yesterday 12:57 AM
New to Berlingos - Impressed so far!
Last Post: RichCowell
29-09-2023 11:03 AM
Appropriate Jumper Battery
Last Post: Abaddon
29-09-2023 09:38 AM
