Reverse Lights not working
Thanks Given: 2
Hi folks, I'm fairly new to Berlingos and I'm having an issue with reversing Lights not working. I'm trying to fit a reverse camera using the reverse light as a trigger.
Bulbs are fine, I've shorted the Reverse Switch Plug but still no lights. I'm getting 3.5 - 4volts on these wires tho.
It's a 2008 plate, 1.6hdi diesel with only 64,000 miles on the clock.
I also can't find fuse number 33 which, according to Haynes Liars Manual, is for the reverse light and ECU (?).
Threads: 75
Thanks Given: 223
164
03-08-2023, 12:45 PM
(This post was last modified: 03-08-2023, 12:51 PM by Sol.)
Hi there,
Engine bay fusebox PSF1 , Fuse F1 (10A) is for the reversing light switch, but it also does the vehicle speed sensor so it if was blown, you would have no speedo.
The reversing lights do not light unless the engine is running, so you cannot test them alone with just the ignition on, and in reverse gear. Doesn't work.
Also, you should not connect anything to them, even a rear camera. You have to use an intermediate relay which draws less than 10ma as the lights themselves are powered from your BSI (Body Systems Interface) computer. If you blow those outputs, you have a world of hurt trying to repair that. The lights themselves are not fused, the BSI outputs drive them directly. I have my reverse camera powered from the rear 12v socket and on all the time with the engine. Works perfectly.
The low voltage you are finding is the Canbus test voltage supplied by the BSI to check if the bulbs blow. It has a warning system of bulb failure. That's why you are not supposed to connect anythign else to them that draws more than 10ma. Massive red & white warning sticker on the light harnesses at the rear tells you that.
Fuse diagram attached.
M59 PSF1.pdf (Size: 262.49 KB / Downloads: 5)
• DiveTramp
Thanks Given: 2
Wow! Thank you very much for that detailed reply. I'll hope that there's not too much "pain" and I'll cut that wire and just use another supply.
Cheers.
Threads: 75
Thanks Given: 223
164
03-08-2023, 09:36 PM
(This post was last modified: 03-08-2023, 09:38 PM by Sol.)
Did you check while the engine was running, and did you have reverse lights before? (I can read posts you've deleted.)
Just so we know the chain of events.
Threads: 44
Thanks Given: 97
28
What about using the gear stick reversing position sensor contacts?
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Given: 223
164
The BSI doesn't turn on the reversing lights if the engine isn't running. Putting the ignition on and putting the gearbox in reverse has no effect unless the engine is actually running.
Threads: 44
Thanks Given: 97
28
Sorry, I meant as a feed from the gear selector to a relay feeding the rev cam, thus leaving the rev lights wiring well alone.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Given: 223
164
(04-08-2023, 07:06 PM)Gryffindor Wrote: Sorry, I meant as a feed from the gear selector to a relay feeding the rev cam, thus leaving the rev lights wiring well alone.
Ah I get you. Sorry, that may have actually worked. I wasn't thinking in the same lane as you, sorry bro.
Smart idea as usual!
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
