Hi,
I have a Citroën Berlingo 1.6D 66KW from 09-2024
Engine code: DV6ATED4 (still need to double check)
VIN: VF77A9HSCAJ653873
When I bought the Berlingo the gearbox was already rattling and now it has gotten worse.
Time to arrange another gearbox for it.
There is now a 20TD48 box in my car and you would think, get exactly the same box again.
However, I get different answers from different dismantling companies:
- 20DP47 is interchangeable with the 20DP48
- 20DP47 does not fit
- 20DP48 will not fit
- According to your fin, 20PD48 does not belong on your car
- According to your fin fits 20DP76 / 20DP63 / 20DP33 / 20ET07 / 20GP96
So I'm still not sure which gearbox to order.
And also what the differences are.
Who can provide more insight into this?
Threads: 42
Thanks Received: 409 in 366 posts
Thanks Given: 137
31
https://www.catcar.info/citroen/?lang=en&l=
Go there and put in your details , it may help you
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 25
Thanks Received: 27 in 26 posts
Thanks Given: 16
6
09-2024?
It's not a Berlingo, it's a time machine...
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
Yep. Aliens, I knew it all along.
Threads: 44
Thanks Given: 97
28
Sounds like the warp core transdrive needs a sonic screwdriver tweak.
Not suire, maybe others can advise, but i it wise to post your VIN?
I'd rather only send it to a mod in a PM if invited.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Given: 223
164
13-08-2023, 08:32 AM
(This post was last modified: 13-08-2023, 08:34 AM by Sol.)
I usually can't be bothered doing this anymore but for anyone who can't search a webpage (as kindly provided by Brodfather11) then here's the item. Though the part numbers are nothing like what the op states.
I can't see why any 1.6 HDi gearbox wouldn't fit, from another B9 diesel.
Threads: 10
Thanks Given: 6
At risk of asking you something you've already discounted - I'd normally associate a rattling with the clutch, rather than the gearbox - are you certain it's the gearbox?
