Help please - I want to buy an old Berlingo
Hi
I am hoping to buy an old Berlingo MPV and have been looking online, including on this site, and have a few puzzles. This post is hoping that someone can teach me. They are
1) Some older ones, 2002 and 2003, with 1.9 diesel engines are listed as 40mpg and others as 49mpg. Is this true and if so what makes the difference?
2) Some are converted for wheel chairs. Can this easily be removed and rear seats fitted?
3) Does the wheel chair ramp modification increase insurance?
Are there any things which I should  be checking on these older models, or other advice on which engine is most relaible or any other tips. Sorry to ask such basic questions but I've failed to find a buyers guide (probably my fault and I'm and am happy to be pointed to one)
Thanks for reading this.
Fingers crossed
Hello and welcome!
When you say some are listed with different fuel consumption, is it what the sellers are claiming? Fuel consumption will vary with driving style, type of journey, condition of engine ect and of course it depends if the seller has actually measured it (and how accurately) or is just guessing.
As far as wheelchair conversions go, I don't think refitting seats would be a goer as the floor would have been modified. But we have a WAV Renault Kango at work which has 2 'jump' seats in the back, probably not ideal for long journeys but could be an option depending on the use you put it to. Also bear in mind that things like the exhaust and fuel tank may not be standard on a converted vehicle so on older ones it may be a case of some lateral thinking/DIY/friendly local garage if replacements are needed
A WAV may of course be low mileage and well maintained compared to a work van, but again depending on the use you're going put it to that can be a double edged sword as issues that didn't come up before suddenly rear their heads as you do more miles.
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
(15-08-2023, 03:54 PM)RattyCortina Wrote:  Hi. Thanks for the reply
The MPGs I referred to were from online searches using the various reg numbers of similar Berlingos for sale, cartaxcheck dot co dot uk. say
I am looking for an economical work vehicle, to do about 10k mile pa, possibly to move sheep (they'd like the ramp) but also when pressed can move grandchildren. Given the age I'm looking at, with a budget of 2 - 3k I suspect having a standard vehicle would mean maintenance would be best if as standard as possible. From what you say about WAV modifications they would make things difficult.
There are not many listed with above 130k miles on the clock. Is that about the usual limit?
Oh what fun this puzzle is
Again thanks for your advice
I now have a 2007 Peugeot Partner Escapade, and it is doing 60mpg.
Great (so far!)
Remember they were made by the million.
You will still have hundreds of owners on forums seeking to repair their vehicles but the remaining majority will have been scrapped because it's no longer cost effective to repair them.
Good luck with the search but caveat emptor.
  • Ed D
On the age you're looking at, I'd avoid (or at least closely inspect) a WAV because the rustfroofing where the ramp's been chopped in isn't always the best.
The 1.9's will do 50mpg all day everyday, probably quite a bit more. I'd assume everyone quoting less isn't doing a lot of miles.
I'm a practitioner of bangernomics myself, I know the letters "HDI" aren't thought of as a good sign, but the old 2.0's are tough old buses.
Buuyer's guide:
Look for air bubbles in the loop of clear pipe on top of the engine (not terrible before you start it, maybe not good when it's running).
Check all the electrics
Make sure the radio works. Seriously, might need a BSI reset (not hard), or could be deeper issues.
Look for rust.
Get someone to rock the back end while you look under and make sure the stub axles are both rotating on the beam.
Anything else isn't going to be terrible.
Could be worse.... Could be a Caddy.
[-] The following 1 user says Thank You to ItsGreen for this post:
  • Ed D
One thing after another
Yesterday 09:01 PM
12-11-2026 10:41 AM
» Replies: 16
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
