Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 306
37
Take a look on youtube, there's videos showing the full job.
https://www.youtube.com/watch?v=8efU4dzH0NY
Threads: 26
Thanks Received: 35 in 32 posts
Thanks Given: 9
11
16-08-2023, 04:41 PM
(This post was last modified: 16-08-2023, 04:44 PM by smutts.)
Buy the cheapest set of metric drill bits you can find.
Choose the suitable pin diameters.
Snap off to suitable length.
Wrap insulating tape around the razor sharp snapped ends.
You now have a cam lock timing kit.
Probably.
230,000 miles, (Resurrected at 186,000)
Threads: 39
Thanks Given: 1
4
You dont need to snap the drills just make sure you use the plain ends to peg the crank and the cam. You will need to support the engine as you have to remove the engine mountaing. You also need to be able to raise and lower the engine to gain access. Dependng on how new the DW8 is the crank gear could b on a floating keyway
Peter
