Threads: 13
Thanks Received: 44 in 29 posts
Thanks Given: 29
I've just filled my daughters car with diesel and I am increasingly of late having difficulty filling it without the pump nozzle auto-stopping. I've tried all different angles etc but it's becoming a right pain. The fuel filler neck does have an anti-siphon thingy which I think was factory fitted and also the car is wheelchair adapted and has a modified tank, but I presume the filler neck is all standard.
The only thought I had was there might be a breather tube blocked.
Any thoughts?
Mark
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Threads: 18
Thanks Received: 24 in 24 posts
Thanks Given: 37
Well if it used to be alright and it’s gradually got worse then somethings up. How about an air line gun down the breather? Can’t think of much else. Can you pull the nozzle back out a little bit more when filling?
Threads: 43
Thanks Received: 410 in 367 posts
Thanks Given: 137
31
I think there was a post not too long ago about the breather valve getting blocked . it also stops fuel leaking out if upturned in an accident.
Cant find the post now but think it was from Zion , something like a spring gets gummed from overflowing fuel running into the air vent ?
Will keep looking
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 13
Thanks Given: 29
Thanks for the replies.
brodfather11 - that would be great if you were able to find the thread, I did do a search before posting but found nothing obvious. Perhaps @Zion might remember. Will have another look myself.
Cheers,
Mark
Threads: 75
Thanks Received: 1,309 in 1,140 posts
Thanks Given: 223
164
21-08-2023, 03:37 PM
(This post was last modified: 21-08-2023, 03:37 PM by Sol.)
Hi Mark, it's here
https://www.berlingoforum.com/thread-207...#pid132495
I posted a diagram of the location of the filter below that post
• MarkT
Threads: 13
Thanks Given: 29
(21-08-2023, 03:37 PM)Zion Wrote: Hi Mark, it's here https://www.berlingoforum.com/thread-207...#pid132495
Many thanks for that Zion, I'll check it out when I get a chance (the car is currently at my daughter's supported living address). Coincidentally I had a PM from a forum member who used to have a similar WAV Peugeot Partner, and he also had difficulty filling sometimes, which makes me think it could possibly be a 'feature' of the convertion and tank modification. Nonetheless I'll check the filter - thanks for the info.
Threads: 75
Thanks Given: 223
164
Ah yes could be, as the wav has a tiny fuel tank. Since diesel foams up when filling, the effect is much worse on a small tank. Worth fuelling it slowly with a part trigger than full bore.
