20-08-2023, 11:03 AM
Hi,
First off, great forum - there is a lot of useful information around and people seem very helpful. For my specific case right now now I have not been able to find any info though.
I bought a Berlingo K9 2020 recently and was under the impression from a previous owner that the Adblue system had been deleted. Well.. Already in my first 500 km I got the famous Adblue-system fault and the countdown begun. The problem is that Im not 100 % sure that the system has been deleted as this info comes from a previous owner than the one I bought it from.
I just got a Diagbox 9.91 to read the error codes and reset the AdBlue system so I can troubleshoot. Firing up Diagbox it says it cant connect/communicate with the Urea ECU.
- Is the Urea ECU the same ecu that is bundled with the NOX-sensor? Or is this a separate device?
When I read the fault codes I receive the two following two faults:
1. U029D 87 : Emissions control CAN network (downstream NOx sensor) characterisation of the fault : missing information
status : permanent
2. P2048 11 : Control of the urea injector characterisation of the fault : short circuit to earth
status : permanent
I have since before removed and cleaned the AdBlue injector but it doesnt seem to help, i will remove it again and try to connect to 12 V to see if it actuates properly.
Regarding the NOx sensor it seems like either the 12 V & GND line, CAN-line or sensor is faulty.
Allthough Im wondering - if the Adblue system has been deleted/mapped be the reason I see this fault?
Lastly, when I try to reset the system in Diagbox with either
Repair --> Spare part --> Replacement of the denox system reservoir, gauge-pump module or pipes
or
Service action --> Work on the Emission control circuit > Reinitialization of the denox systemD
Diagbox stops at the last stage with the message: "procedure terminated".
I'd like to think Im following the steps the right way but can't seem to do any service or repair action. Could this relate to not having contact with the Urea ECU or that the system might have been mapped already?
So to sum up my questions:
1. Is the Urea ECU the ecu that is connecting to the NOx-sensor? Might it be that I can't complete the service or repair action below because I can't communicate with this ECU?`
2. If the system has been mapped would that also prevent me from using these options in Diagbox?
The cable I have seems legit and Im able to read all other values without any problems.
Im a little bit stuck where to go next with this, any advice is highly appreciated. I've attached the report from Diagbox below.
I still have around 500 km to go before the van wont start.
status : permanent
status : permanent
or
