26-08-2023, 05:50 PM
Hello folks. Really stumped here so any help would be massively appreciated.
I was basically gifted my current Berlingo which had been parked up for quite some time. It had a few obvious issues such as horrible noise on start up and was pulling back slightly when being driven. Lexia stated I had an EGR and Injector problem also.
Upon inspection, we replaced the EGR valve as well as the tension wheel and a new drive belt which fixed the weird noise when starting and the car still started and drove but was still pulling back slightly.
We noticed a leak on top of the Injectors so removed them to replace the black seal and the small copper seal. Once they were out they were a real mess, lots of horrible black stuff and one of the injectors had some rust.
We cleaned both the injectors and the bore holes (I'm hoping that's the right word lol) thoroughly before replacing the seals. The fuel pipe that connects to the injectors was also replaced by one from ebay as it literally broke in two when we handled it. Because of all the black dirt inside of where the injectors are we also put on a new fuel filter.
I must note that due to weather there was a point where I had to wait a week to finish these jobs so probably let a lot of air into the system.
Now the car refuses to start, it simply turns and turns. I've bleeded the system using the hand pump on top of the engine but had no luck whatsoever. Firing some easy start in starts the engine but it immediately runs off as if there is no fuel Being fed to the injectors.
Has anyone else had this problem and found a solution? I'm running out of ideas and am definitely down about it. I'm based in Yorkshire and would be happy to pay for someone who knows their stuff when it comes to this problem with Berlingos to get it running as I am not great with mechanics and was simply trying to save some money in getting the car running nice.
Cheers all.
Cheers all.
