[Engine] Fumes still after 5months
Hello
I have a 2018 B9 van with 54000 miles on it .In March of this year i started getting fumes in the cab.
So far i have had the head oil leak done , a new water pump fitted tightened every easy access cap and clip i can see .
Slowly the fumes have eased but im still getting a sore throat and an unpleasent taste after driving the van .
I have had the exhaust checked and it has no leaks .
If i accelerate hard i get an oil smell .
I have looked under and over for any signs of oil blow but can't see or touch any anywhere .
HELP ANYONE!!!!!
Is there anything i should be looking for , tightening or replacing . Other than the fumes the van runs perfect , it did 700miles on a full tank of diesel during a trip to Scotland and didn't miss a beat .
There can't be much wrong with it other that its causing me stress and throat issues .
Do any of you have any answers please
Rear door seals , if gaps in them they can suck exhaust fumes into the vehicle.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(31-08-2023, 01:21 PM)Scrag27 Wrote:  Hello
HELP ANYONE!!!!!
You haven't mentioned a check of/tightening of the injectors. The injectors are well known for working loose and causing fumes.
I had a similar problem with smell and fumes. Did lots of searching checking seals, a.c. radiator etc, even extended the exhaust tailpipe as I thought fumes could be coming in that way.
Its worth checking the top of the injectors for leaks as Multispacer has suggested. If they are leaking there is normally a chuffing noise from the engine and black deposits at the top of the injector/block interface.
In the end I found it was a leak from around the EGR valve. Trouble is you won't see it and its buried with fuel filter, air filter and battery in the way. I took time to make sure the EGR valve lined up perfectly and had a new metal gasket. Something to try when you have already eliminated the easier to solve other possible causes.
Diagbox 7.57 download
Today 09:13 PM
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
