  • 17 Vote(s) - 2.71 Average
very stiff change/great service
2002 2.0HDI Multispace, the gear change was never that good when I got it in in 2006 (it was on par with the 1.9D I had before) but it became very stiff over the last month. had a swift look underneath but masked by the exhaust. So I bit the bullet & took it to Marsh citroen repair http://www.marshcitroenrepair.co.uk they put it on the ramp & sure enough the shouldered bolt/pin was partially seized 15 mins later I had a gearchange that I never had in either berlingo I had owned, all for 15mins labour, about £13.00 saving me the hassle of trying to jack and axle stand it high enough to get at while lying on my back. Great job, I have used them before always a fair price and with 30 years citroen experiance.
Hi Husqyman,
Which bolt is it? The clutch pedal pivot bolt?
Regards,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Sounds like the east Kent owners should be giving them some biz!
Your link isn't quite right, should be:
http://www.marshcitroenrepairs.co.uk
  • andy-womble
(22-03-2012, 05:22 PM)Landmark Wrote:  Hi Husqyman,
Regards,
Griff
No it was the bolt at the bottom of the gear lever
(22-03-2012, 05:31 PM)OlJeffers Wrote:  Sounds like the east Kent owners should be giving them some biz!
Many thanks for the correction. They are good people
I can recommend this one in Kent - http://hillsmotors.co.uk/ although their address is wrong on there as they've just moved ( Unit 21/Riverside Est/Sir Thomas Longley Rd Rochester ME2 4DP)
I won't be using them - never worth the cost of the fuel!!!!!
Always good to have a recommendation though and if they are as good as you say, good luck to them !
Rear light cluster removal
Last Post: phydaux
Today 11:47 AM
Cranks but won't start
Last Post: MarkA67
Today 10:45 AM
Last Post: BrianS
Today 10:35 AM
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
Yesterday 10:07 PM
Engine Fan Running
Yesterday 09:59 PM
Bettery Issues - A Solution.
Yesterday 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
