  • 13 Vote(s) - 2.69 Average
heater blower
hi folks
im new to this forum
my 2005 hdis heater fan has stopped working on all levels, how do i access the blower itself? i know its a common problem, i know its located behind glovebox but how do i get at the dam thing lol?
paul
Get to it from underneath, pull the caret down, three screws holding it in.
Hi, do a search for heater blower resistor on the forum.
Might give you some pointers Confusedtudy:
Confusedalut:
hi folks
thanks for the replies, is starhead screws or torx type screws holding it in?
(23-03-2012, 08:18 AM)paul coey Wrote:  hi folks
Most probably Torx.Confusedalut:
6mm headed self tappers on mine.
Have a read of this. May help:
Blower repair / removal
They should be 6mm bolts you can remove with a standard rachet set.
I'm stuck with this... I took my blower apart from a 02 berlingo multispace. There is no transistor pack inside it. The blower only works on the highest speed setting, 4.
Is the transistor pack/heat sink thing hidden somewhere else?
(15-11-2012, 10:26 PM)Conceptguy Wrote:  I'm stuck with this... I took my blower apart from a 02 berlingo multispace. There is no transistor pack inside it. The blower only works on the highest speed setting, 4.
My 2003 2.0 hDi does exactly the same (stuck on 4), and I've just bought a new resistor which hope to fit over the weekend...
Hopefully thats whats wrong with it anyway:whistle:
Thanks. Ive taken the blower motor out but there is no transistor pack attached. I assume by all the pictures I've seen it should be attached to the motor housing??
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
