2018 oil leak
Hello all,
I have a 2018 berlingo 75bhp and have noticed a slight oil leak from what I think is the egr pipe (can’t see Any higher or deeper, but the oil seems to be coming from there and dripping down onto my driveshaft and spraying the oil pressure switch too.
There are no puddles being left and only noticed this when I serviced the van.
Is this a common leak from said egr pipe or is there a usual spot these leak from?
Thanks paul
Attached Files Thumbnail(s)
Not common. The EGR only carries exhaust gases. Could be a leak of oily vapour from the EGR but it can't leak actual oil. There is no oil supply to the EGR circuit. Or you have a much bigger problem.
(07-09-2023, 05:39 PM)Zion Wrote:  Not common. The EGR  only carries exhaust gases. Could be a leak of oily vapour from the EGR but it can't leak actual oil. There is no oil supply to the EGR circuit. Or you have a much bigger problem.
I did think it’s an odd place to come from it’s not loosing much oil I’ve done 3k since the service and went down two little notches on the dipstick.
I’m not sure what oil was in it before but it’s done 130k and it wasn’t leaking when I serviced it the oil I put in was 0w 30 recommend by opie oils, could this cause an issue?
I've done 8k since my last service, to hit 69k and the oil has never dropped even a millimetre on the dipstick, two notches is about half a litre?
0w30 is a bit watery. Should be 5w40 fully synth.
There wouldn't be a puddle if you have the undertray, it catches it all.
Yeah so must be leaking from somewhere then, it’s going in for a cambelt next Friday so will get them to look at it then,
It never came with a undertray and doesn’t puddle or leave drips at all, it goes straight on the drive shaft and gets flicked about.
I do have an undertray to go on after the leaks fixed ready for winter
May be the oil switch leaking and the driveshaft is throwing it about?
Yeah defo an option! The back of the engine isn’t wet just the switch and a damp patch on the drive shaft, thanks for the suggestions/ help
Where is 2011 Berlingo parking sensor ECU?
Last Post: Gene1
Yesterday 09:28 PM
BSI
Last Post: jemselectrical
Yesterday 08:53 PM
» Replies: 16
M59 BSI Technical Document (Citroen Training)
Last Post: Zion
Yesterday 07:07 PM
Cup Holder Fitting
Last Post: Gadgetman
Yesterday 05:54 PM
Electric probs - where to start
Last Post: BigVtwin996
Yesterday 05:26 PM
Stuck glow plug tip - I've tried it all - It won...
Last Post: DeSender
Yesterday 05:15 PM
Berlingo/partner 2019 Gearbox real or fake?
Last Post: Zion
Yesterday 04:59 PM
Removing footwell carpet - problem
Yesterday 09:05 AM
Rear back door air gap??
Last Post: Gene1
Yesterday 08:24 AM
Problème ABS
Last Post: Zion
Yesterday 07:36 AM
