Thanks Given: 1
Would anyone on here be able to help me out, I'm trying to find a pinout diagram for the lock/unlock dash switch.
Many thanks in advance!
Threads: 75
Thanks Given: 223
164
07-09-2023, 05:33 PM
(This post was last modified: 07-09-2023, 05:36 PM by Sol.)
It goes to the BSI computer for processing. Body Systems Interface. What is it you're trying to do? Because the switch just signals the BSI you want to lock or unlock the doors, and it does the function for you. It controls everything.
My mystic senses tell me you're trying to add aftermarket central locking....yours doesn't work.....aaah the mist is descending....key issues after battery replacement....
Nah lost it, crystal ball has given up.
Thanks Given: 1
My remote locking isn't working because I have a clone Chinese key, so I'm going bluetooth on the new system. Built in encryption, and auto locking/unlocking within 3m of the van.
Threads: 75
Thanks Given: 223
164
Lol - bingo, I'm good. Chinese key....encryption....hmmmm
Ok let's see...diagrams below, may not be as easy as you hoped. But not too bad. It's a toggle function. Non latching.
Central locking (6220 is the button)
Central Locking.pdf (Size: 353.56 KB / Downloads: 17)
Component ID for schematics
Citroen Components.PDF (Size: 153.2 KB / Downloads: 11)
Wiring colours (schematics colours are in French)
wiring legende.pdf (Size: 73.44 KB / Downloads: 7)
Thanks Given: 1
Non latching is perfect, less wiring! Just one trigger wire to sort, now just to find out if it grounds or gives 12v positive when pressed....
Thank you! I shall do some reading and hopefully find out!
Thanks Given: 1
OK so when pressed it goes to ground, absolutely perfect! Saves extra relays etc.
Zion you are a saviour. You've saved me a lot of soldering!! Thanks dude!
Threads: 75
Thanks Given: 223
164
09-09-2023, 08:01 AM
(This post was last modified: 09-09-2023, 08:02 AM by Sol.)
You're welcome!
Big benefit of the switch is that even the load bay doors lock & unlock with it.
Threads: 75
Thanks Given: 223
164
27-10-2023, 09:46 PM
(This post was last modified: 27-10-2023, 09:46 PM by Sol.)
It's a toggle switch. Yes it's N/O but it's action is TOGGLE!!!!!
