[Engine] Crank not start
Hi to all ,
I have a berlingo 1.6hdi b9, 2017, 68900km and I have the following problem, I start the engine, it rotate but does not start, after checks the low pressure pump does not supply diesel so I replaced it with a new one and that's it don't put in the diesel, with the diagnosis it doesn't give any error code except pressure lack of low pressure circuit
Can anybody have a clue
Update, after diag box scan have error P2635 00 &U1218 81
What did Diagbox say those codes mean? Diagbox gives an exact fault, not just a code.
I ask, as I can't find those codes at all on the official list.
P codes are engine faults and U codes are communication faults.
P2635 Pompe basse pression carburant
U1218 81Défaut de communication avec le boitier de servitude intelligent
,,ask, as I can't find those codes at all on the official list." yes I know, I also searched in the "haynes pro" database and I have no reference
SOLVED: P20F6 fault
Today 08:28 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
