2022 Berlingo Auto Van Power Steering Fault
Hi
I have a 2022 Berlingo Automatic Van.
Sometimes when I've been out in the van, then stop for 10 minutes or so, then restart the vehicle the power steering fault warning light comes on & I have no power steering! if i then leave the van off for 1/2 and hour to an hour then restart the vehicle it works fine again.
This has happen about 20 times since having the van, it never happens first thing in morning, it only seems to happen when the vehicle is hot.
Any ideas anyone ?
Thank you
Since it's under warranty and sounds like an issue with the electronic power steering system, I'd go to the dealers and get them to sort it.
EPS is not something you are likely to fix at home and no one will be able to reliably scan it for fault codes except a dealer or approved Citroen garage due to it being so new. Regular scan tools mostly do not work on them and what few that do work, can only pull engine codes and then, badly.
(12-09-2023, 05:27 PM)Zion Wrote:  Since it's under warranty and sounds like an issue with the electronic power steering system, I'd go to the dealers and get them to sort it.
EPS is not something you are likely to fix at home and no one will be able to reliably scan it for fault codes except a dealer or approved Citroen garage due to it being so new. Regular scan tools mostly do not work on them and what few do, can only pull engine codes and then, badly.
Thank you, will definitely get in touch with the dealer again.
Many thanks
No worries, sorry we can't be of more help on this occasion but please let us know how you get on, it's always helpful to others who may come along with the same issue.
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
