Threads: 8
13-09-2023, 06:15 PM
(This post was last modified: 13-09-2023, 06:27 PM by Killerdelts.)
Hi what's a good oik and filter for my citroen berlingo van b9 diesel 2013 1.6 75hp thanks is it 5w 30 fully sim thanks
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
05-10-2023, 06:18 PM
(This post was last modified: 06-10-2023, 10:09 AM by evdama.)
There is a specific variant of 15/30 Low Saps made by Mannol for our PsA Group vehicles
MANNOL Energy Formula PSA 5W-30 7703
But it's pretty scarce in the usual UK places.
You need to bear in mind the pain that consumers went through with early Dv6 engines and take the lessons learned about oil issues.
I use Total quartz ineo.
Certainly not cheap but it's the recommended product by PSA.
You can get genuine (Mahl) filters for reasonable money on eBay if you look around
1109ay is the part number.
Don't forget a new sump plug washer
20x10x1.5
Threads: 75
Thanks Received: 1,310 in 1,140 posts
Thanks Given: 223
164
07-10-2023, 08:13 AM
(This post was last modified: 07-10-2023, 08:14 AM by Sol.)
Yeah, lots of turbo failures on the early dv6s due to carbon build up and coking back then.
Threads: 81
Thanks Given: 165
20
Shtus well meaning link was for a C3 rated oil- which is high Sulphur ,Ash and Phosphurs ( Saps)
These are additives for the benefit of many engines but in some ,such as the Euro Diesel, they can block DPF's or even close off oilways, so a low rating, C1 should be used.
Back in the day you could just glug some Castrol GTX in and be done with it ....
Threads: 81
Thanks Given: 165
20
(07-10-2023, 06:47 PM)shtu Wrote: That's weird. 7908 is listed as a C2 spec on their own site, which is perfectly OK (and what is specified almost everywhere for the 1.6 hdi)
https://www.mannol.de/products/synthetic...mium-5w-30
I've emailed them to find out what they have to say.
(edit - oddly, the bulk packaging images state both C2 and C3, the images of the retail pack say c3. I CBA going out to the garage to read the label myself.
You're right
I've just looked deeper.Total Quartz is a C2 as well,but the ACEA a have also recently discontinued the C1 spec which will add further confusion.
Definitely avoid the C3 though.
Threads: 41
Thanks Received: 82 in 75 posts
Thanks Given: 129
9
The Total Quartz 0w20 oil recommended for use in my K9 (1.5 BlueHDi) is rated as ACEA C5, but it also says 'Low Saps Particulate Filter' on the can, so I'm wondering what the C-number actually means?
