Gearbox no5-6 and reverse gear
Hi
I have a berlingo 2019 reg 1.2 puertch petrol manual
And while I was driving at the roundabout I have lost 5and 6 gear
When stopped at parking realized as reverse doesn’t work too
While charging the gears I can’t fill any difference
Just when I release the clutch pedal at 5or 6 it’s the same as neutral
If anyone got some suggestions please comment
Thank you
Could it be a cable dropped off the gear changing gubbins at the g/box end ?
That is if it is cable operated like the vw caddy.
If it was inside the gearbox would you not feel some pressure when working the gearstick.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(16-09-2023, 06:57 PM)brodfather11 Wrote:  Could it be a cable dropped off the gear changing gubbins at the g/box end ?
There is no pressure when I switch to 5or 6 it looks as I switch to neutral
But revers - I can’t even switch to it, just if I holding gear shift under pressure. Otherwise it doesn’t get in position
Sounds like you need to take it to a garage and let a qualified mechanic look at it. You aren't going to fix this on the road side.
Air filter box removal
Today 12:47 PM
Berlingo undertray
Today 12:42 PM
» Replies: 21
Yesterday 10:10 PM
» Replies: 21
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
