Threads: 20
Thanks Received: 47 in 44 posts
Thanks Given: 34
4
when my battery died, a friend came with another car, put the jumper wires from his car to my car, then started his car, let his car charge my car's battery like 5mins, then stopped his car, and I started my car without any issue, then disconnected the jumper wires.
If you like gaming visit
GameForest
Threads: 22
Thanks Received: 25 in 23 posts
Thanks Given: 103
7
I tried that and still no change. Completely baffled by it tbh
Sent from my Pixel 6a using Tapatalk
Threads: 68
Thanks Received: 1,171 in 1,037 posts
Thanks Given: 194
147
18-09-2023, 11:00 AM
(This post was last modified: 18-09-2023, 11:04 AM by Zion.)
Have you tried starting the engine? I know that sounds daft but eco mode is always on after about 15 mins of having the ignition on but not running, then starting the engine resets it back to normal again. The dashboard ignition display will look funky in eco mode, with a flashing battery symbol and eml lit, but starting it still should work and puts things back in to normal. I.e. just start it and ignore the dash warning and lack of life in the clocks, it resets when the engine starts.
I feel a DOH moment coming (hopefully)
If you need to disconnect the battery or have run it dead, take it off and charge it up, then replace it. That generally works better than jump starting on these, though I have done the latter and it worked ok with a big jump pack and using the passenger inner wing earth stud (don't use the engine alloy bits)
The following 1 user says Thank You to Zion for this post:1 user says Thank You to Zion for this post
• jemselectrical
Threads: 22
Thanks Given: 103
7
Initially when I tried to start it, it made a clicking sound, as if attempting to turn the starter motor, when turning the ignition, but after about 5 attempts that stopped and all it would do was make a whirring sound which I think is the throttle body initialising. Now it just displays economy mode for about 10 seconds, then flashes the battery light and the engine light stays on. Almost as if it's in sleep mode and will not turn over let alone start
Threads: 20
Thanks Given: 34
4
the clicking sound and not starting is the simptom of a dead battery (mine does the same thing!)
I suggest you get a new battery if you already checked the battery connectors (maybe are loose?!?)
GameForest
Threads: 27
Thanks Received: 372 in 326 posts
Thanks Given: 63
19
Clicking can also be a sign of a bad earth or a stuck starter, have you had a meter on the battery to see what charge is in it ?
