[Engine] guide pulley auxillary belt correct torque?
Hi All,
Have not posted in some time, but too busy with work.
The alternator of my 1.6HDi M59 2007 (no aircon) packed up a bit, so decided to replace it. I have undone the two guide/roller pulleys that hold the two bolts on the alternator, but wanted to make sure that I will have the correct torque when putting them back on. Reading the workshop manual for my 9HXC engine, these bolts seems to be torqued to 45Nm. Seems quite a bit for these pulley bolts.
Can anyone confirm that these are 45Nm?
In addition, on taking the v belt off, it was labelled as 6PK1350, where any belts I can find that fit my 1.6HDi, no aircon, are all 6PK1353. It was not replaced by me and probably 2-3mm do not make that much of a difference.
Many thanks for any help, more than appreciated!
Shamelessley to bump it up a bit :-). Does anyone know these?
Do you have ServiceBox? This info must be in there mate. I can have a look for you if not.
(22-09-2023, 05:58 PM)Zion Wrote:  Do you have ServiceBox? This info must be in there mate. I can have a look for you if not.
Thanks Zion, I looked at ServiceBox and it was given as 45Nm, but it seemed way too high. Probably correct, but just wanted to make sure.
Mileage
Last Post: Taffy747
Today 11:51 AM
Today 09:17 AM
Yet another ABS fault
Yesterday 10:13 PM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
