2020 Auto Not Starting
Hey,
Any automatic owners ever had a problem with the van no starting?
A big spanner appeared on the speedo display and then after I stopped the van wouldn't start again. No other warning lights appeared.
It sounded like a ticking noise. Starter motor maybe?
I got the AA out and he tried and failed to get it started.
He checked the battery, thought it was low on charge so tried to jump start it. No joy there. He then checked the fuel... NO I didn't put petrol in it. Lol.
Then onto diagnostic, the machine showed the fuel pressure at 5 psi? He said it should be in the hundreds?
The week before my GF said my lights didn't seem as bright so could it be the battery is indeed faulty and its somehow immobilised itself?
The AA couldn't tow as it was stuck in a gear?
No power though with the wipers, windows etc not working and just 3 lights on it.
Anyone any ideas?
It's at my local garage awaiting them looking in the morning.
Cheers
Jamie
Sent from my SM-S901B using Tapatalk
you need to replace the battery and perform bsi reset
If you like gaming visit GameForest
[-] The following 1 user says Thank You to deejay_xb for this post:
  • jmgassltd
(19-09-2023, 05:28 AM)deejay_xb Wrote:  you need to replace the battery and perform bsi reset
Wasn't that. 2 batteries tried just incase. Garage suggest it's the camshaft linkage?
When I read your first post I thought it might be this.  Is your engine the 1.5 BlueHDi?  The camshaft chain is a known weakness on these engines, though getting Citroen to admit it isn't easy.  The last dealer I went in said he had 2 or 3 vehicles in the back with the same problem.  The recommended engine oil has been changed to try and address the issue and prevent breakage, though that of course doesn't help if it's already broken (read through this thread for extra info: https://www.berlingoforum.com/thread-23596.html)
My garage are saying its the gearbox stuck in REVERSE hence not starting. That possible?
Cost 3.1k yo sort.
4 months out of warranty
Could be. Ouch. Good job it won't start then.
There's a system to prevent starting in gear of course, as that would be disastrous. So yes it will not start (or even turn over) in gear, reverse or otherwise.
And after 2 months. The problem IS BACK.
I am scunnered and skint. A gearbox was fitted.
It's ticking. I may change the battery as first suggested but took the word of a garage that the battery was trued twice.
FFS man. Anyone got a....
Is it stuck in gear again?
I drove a Volvo truck 5 years or so ago and if you turned that off while in gear it was a auto and then it lost air pressure it wouldn't start up again it was a call out to Volvo to sort out the newer ones know don't have a problem.
SOLVED: P20F6 fault
Today 08:28 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
