Crash sensor part N
Hi All, I’m new to this site and would really appreciate some help, I need to find a part number for the passenger side airbag crash deployment sensor 2008 1.6 hdi m59 or if a later model sensor will fit and if anyone has one for sale that would be great.
Cheers Pete
I'll have a look at work. If it's been crashed, the crash data is stored in the Airbag ECU. It can't be cleared. The only way is to replace it with a new one and have it coded to your vehicle with Diagbox.
If it's just a sensor you need and this isn't the case, we can try to get a part number.
This is a very uncommon request so not sure on late model sensors.
(21-09-2023, 06:39 AM)Zion Wrote:  I'll have a look at work. If it's been crashed, the crash data is stored in the Airbag ECU. It can't be cleared. The only way is to replace it with a new one and have it coded to your vehicle with Diagbox.
Hi it’s not been in a crash, scanner keeps telling me it’s the sensor
 Cheers for your reply
What scanner are you using and what is the code generated? Most aftermarket scanners either don't work or produce nonsense codes on Citroen.
Looks like the crash sensor part number is 9636982680 for the M59. There are some on eBay.
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
