Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Where is the sensor for the electronic dipstick?
How does it work?
Mine has been working fine up till last few days. It is now saying 'min' when the physical dipstick is saying 'full'.
Know which method I believe (the wet oily bit, not the flashing light bit).
Threads: 21
Thanks Received: 36 in 34 posts
Thanks Given: 6
If you are parked on a slope it changes alot unsure of location of part you require tho
The following 1 user says Thank You to muply for this post:1 user says Thank You to muply for this post
• j90xxx
Threads: 41
Thanks Given: 82
6
I just thought they didn't work properly, mine has never been right, just find it easier to check manually.
The following 1 user says Thank You to Mike for this post:1 user says Thank You to Mike for this post
• j90xxx
Threads: 63
Thanks Given: 410
Mine's the same Martin. Very unpredictable as stated in previous postings on here.
Old technology of dip/wipe/redip and ok never let me down thus far...
