Mk II 2018 Anniversary Door Sill Clips?
Hi all, thanks for all your help in the past. Unfortunately I can't find anything on this so I'm asking for advice etc.
I think my Berlingo was used as a tractor by a previous owner because its had so many knocks underneath.
I'm trying to locate an annoying noise from under the car which I currently suspect is from the plastic exterior door sills.
There are 3 what I assume are places for clips but neither side has any in place and as a consequence they make a lot of noise
Can any other owners confirm if there are clips of some sort to keep these from rattling please?
Cheers
Jerry
Maybe try http://www.catcar.info but it won't recognise your VIN, but it's an online parts system with Citroen in it. That gets the part numbers. Switch it to English as it's in Russian.
Edit, I had a look. Think its these part numbers:
703025 - clip
6991S6 - hog ring it says. It's a trim rivet.
Page is here: (item 80 & 81) - click each part number for a supplier list or search Google / eBay with these numbers.
https://www.catcar.info/citroen/?lang=en...aWVyPT0%3D
  • Jerry123
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
