front hubs
Hi can anyone tell me if the front hubs are the same for the van and multispace.
are they fitted to anything else
its for 2012 multispace 8v
thanks
Identical. I fitted these to mine:
https://www.ebay.co.uk/itm/183659768576?...media=COPY
Sent from my Pixel 6a using Tapatalk
Along with new wheel bearings. They have the abs sensor ring built in:
https://www.ebay.co.uk/itm/313166698368?...media=COPY
(24-09-2023, 07:12 PM)jemselectrical Wrote:  Along with new wheel bearings. They have the abs sensor ring built in:
thanks for the fast reply i was looking at used complete hubs as i don't have a press for the bearings and a mechanic i know said he has bad success replacing with new bearings as i gave an abs fault .plus i can remove and replace in one go dont have a garage working in the road
Just bear in mind that the old wheel bearings will be toast as a result of removing the hubs. I paid my local garage to press in the new ones for £70. Just take the knuckle assembly to them after drifting out the hubs and they'll press out the shagged bearing and then press in the new ones.
(24-09-2023, 07:23 PM)jemselectrical Wrote:  Just bear in mind that the old wheel bearings will be toast as a result of removing the hubs. I paid my local garage to press in the new ones for £70. Just take the knuckle assembly to them after drifting out the hubs and they'll press out the shagged bearing and then press in the new ones.
i was going to get a complete second hand knuckle and swap over then i can put new bearings in the old knuckle at my leisure
Breakers then. You'll probably be in for £70 to £80 odd for a pair of complete knuckle assemblies if you're lucky
are the van and car ones the same?
(24-09-2023, 08:03 PM)mopedracer Wrote:  are the van and car ones the same?
Yes.
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
