Engine flush
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
25-03-2012, 07:03 PM
(This post was last modified: 25-03-2012, 07:48 PM by j90xxx.)
Does anyone recommend flushing the engine when changing the oil?
I have changed mine twice (9 - 10k miles each with new filter) in past 12 months, without flushing and oil is black again within days.
Realise the importance of a clean engine (correct oil, turbo problems, dpf, etc) so if a flush is to be done what would the Forum recommend using?
Do Citroen flush when changing oil?
Have read the pdf on servicing, and it is not mentioned. Just importance of oil temperature and drain time.
Opinions, please...
http://www.stp.eu/uk/products/item/id/52/engine-flush
And does anyone recommend an OIL ADDITIVE, after changing the oil?
Threads: 32
Thanks Given: 13
Citroen don't flush it, unless you ask and pay extra.
I had it done once as they threw it in as a job clincher when I got quoted less by another main dealer, when it was under warranty.
I actually changed my oil today. It had done 8k since last time and I drained it then ran through half a litre of clean cheap oil to wash out the base of the sump. Then filled it up with Castrol GTX.
If you wanted to get it cleaner you could run it for a couple of hundred miles then drop it and fill with clean again, but it's probably going overboard. I bet it still won't stay clean for long.
Regular changes are the best bet for me, so I am aiming for twice a year.
The following 2 users say Thank You to tucker for this post:2 users say Thank You to tucker for this post
• j90xxx, ron
Threads: 51
Thanks Received: 35 in 32 posts
Thanks Given: 3
No additives just good oil,
No need to flush diesels are just like that. Oil dirtys within 5 mins
If ya really want to do it, drain, fill with a cheap oil, run for a min or 2 and drain again. Then the proper oil
The following 1 user says Thank You to corkgsxr for this post:1 user says Thank You to corkgsxr for this post
• j90xxx
Threads: 20
Thanks Given: 2,126
18
If you use good oil & change it regularly,there is no need to flush
When buying a secondhand vehicle use a good product(I use Forte),& flush.Then use good quality oil & filter.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• j90xxx
Threads: 101
Thanks Given: 384
Thats what I was thinking.
Oil was changed 3 weeks/1,000 miles ago.
Might drop it this week and refill with new.
Would you recommend new filter, or not after such short time?
Threads: 51
Thanks Given: 3
(25-03-2012, 09:08 PM)j90xxx Wrote: Thats what I was thinking.
Yep New filter, if your going to that effort oil filters are cheap
Threads: 20
Thanks Given: 2,126
18
(25-03-2012, 07:03 PM)j90xxx Wrote: Does anyone recommend flushing the engine when changing the oil?
Opinions, please...
Definately change the filter,it holds a 1/4 litre of dirty oil.
• j90xxx
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Don't understand what all this worrying is about.
I know its not a 1.6 but with my 2.0 i do an oil change every 6 months and use Shell helix 10w40 or similar and the engine is sweet as a nut.
Keep the oil changes in sync with the sort of driving or mileage you do and yu'll be sorted.
Just as another point, dropped my oil on Friday after 4500k and even today when it was checked the oil was still clean. Amazing!!!
Threads: 26
Thanks Received: 12 in 8 posts
Thanks Given: 18
What or how do you flush the engine?? I had a guy advise me to put a half liter of Home Heating oil or pariffin into the engine and let it tick over for 10 - 15 minutes before draining the oil out...
What affect would this have on the internal workings??
Threads: 63
Thanks Given: 410
(19-06-2012, 09:32 AM)prunty Wrote: What or how do you flush the engine?? I had a guy advise me to put a half liter of Home Heating oil or pariffin into the engine and let it tick over for 10 - 15 minutes before draining the oil out...
Will do an excellent job of removing the lubricating properties of the existing oil from bearing surfaces etc thus rapidly increasing mechanical wear. Best done with the engine really hot then rev the knackers off it for 20 minutes or so to speed up the process of knackering an otherwise good engine.... then report back on how much engine you have left at the end of it.:whistle::whistle::whistle::whistle:
Wouldn't even think of it, if you value your engine buy a decent engine flush designed for the job...
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
