Turbo to DPF gasket
Threads: 3
Dose anyone know the exact part number for the gasket between the turbo and the dpf. I have scoured the internet to no avail and the best i have found is an image that shows it on the Citroen parts direct site under another part listing.
It is number 17 on the image below.
I have fumes in the engine bay and i'm pretty sure it's coming from this join. Read that if this join isn't made before securing the lower DPF mounting bolts it's always going to leak.
Hope is i can get the gasket, loosen the dpf, make the join, tighten the DPF and not die of carbon monoxide poisoning.
Thanks Received: 69 in 64 posts
Thanks Given: 2
10
This is a job for your friendly local parts factor, anyone that sells exhaust components will be able to get those.
I reckon this is the part you're after, but they'll be able to check,
https://www.ebay.co.uk/itm/262693333255
Threads: 3
(04-10-2023, 08:01 AM)shtu Wrote: This is a job for your friendly local parts factor, anyone that sells exhaust components will be able to get those.
I had considered that the aftermarket part might look nothing like the original shown in the diagram or my Haynes manual. I need a service anyway so might flag it with mechanic then and get some expert opinion. I just like to know what a problem is and potential resolution before taking it my mechanic when i can
Threads: 3
Think i found it!
Searched for turbo gaskets, found a mounting kit that had the correct looking part in it. Clipped the image...
done a google picture search and...
https://www.parts4sale.co.uk/peugeot-cit...808330980/
Now the question is am i going to be able to do this on the cheap myself or make a mess of it and be out even more money than i would have done letting a pro do it?
Threads: 75
Thanks Given: 223
164
To get part numbers, use http://www.catcar.info, set to English, enter your VIN or if not recognised, drill down through Citroen, Berlingo etc till you find the section you want. The part numbers are listed beside the diagram numbers.
Thanks Given: 2
10
Good to know that ^
Fed that part number through eBay, got https://www.ebay.co.uk/itm/325754073548
Threads: 3
(04-10-2023, 07:44 PM)Zion Wrote: To get part numbers, use http://www.catcar.info, set to English, enter your VIN or if not recognised, drill down through Citroen, Berlingo etc till you find the section you want. The part numbers are listed beside the diagram numbers.
Thank you, really useful that.
Only thing is i went through multiple engine variants and none of the ones i seen showed that part. My VIN wasn't recognised either.
Threads: 3
(04-10-2023, 09:51 PM)shtu Wrote: Good to know that ^
Thanks, i searched for the part number on autodoc and it confirmed the fitment against my reg. Ordered from your link as the genuine part was going to be the same price as the aftermarket.
Threads: 75
Thanks Given: 223
164
(05-10-2023, 07:00 AM)ManWithNoVan Wrote: (04-10-2023, 07:44 PM)Zion Wrote: To get part numbers, use http://www.catcar.info, set to English, enter your VIN or if not recognised, drill down through Citroen, Berlingo etc till you find the section you want. The part numbers are listed beside the diagram numbers.
Sometimes it takes a lot of hunting on there, things are often not in the section you think they would be.
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
