[Filters & Oil] Berlingo Van - Oil Leak
Hi All,
New member here,
2016 berlingo van 1.6 blue hdi - auto box.
I’ve located an oil leak, which seems to be coming from a braided cable from
 the oil a sump (see pics )
it would be great to understand what this part is, if it is a common leak and if a replacement part would fix the issue.
Thanks in advance for any help.
Attached Files Thumbnail(s)
Is there not a oil level indicator which fits in the sump. Gives a estimate of the oil level when ignition is switched on.
Could be that or the gasket which is leaking ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • m.lev
These are just corrugated plastic covers over wiring. The lower messy one looks like the cable going to the Adblue injector under the DPF. There shouldn't be oil in there, it's getting in from somewhere above the engine end of that cable protector..
It doesn't carry oil at all so you have to find out how it's getting inside there. Nothing meant to be in there but wires and fresh air. Has to be getting in from above the other end and running down then out.
(04-10-2023, 08:58 PM)Zion Wrote:  These are just corrugated plastic covers over wiring. The lower messy one looks like the cable going to the Adblue injector under the DPF. There shouldn't be oil in there, it's getting in from somewhere above the engine end of that cable protector..
Thanks Zion,
Appreciate you taking the time to respond.
I’ll investigate.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
