Gear Cables Top Tips
While I'm doing the clutch, may as well do the gear cables too - they were pretty seized, putting them next to the exhaust with next-to-no heat shielding is a "great" "design" "feature".
They come out easily enough - remove the dashboard bits,  disconnect the inners and outers from each end and PULL, but getting them back in is  bit trickier, as the rubber grommet and plastic clip is tricky to get through the floor at the correct angle.
Top Tips,
Silicone spray, liberally over the floor opening, and the grommet.
Pass the cables through, and pull the outers through as far as they go (ie, the ends are against the grommet inside.
From under the car, grip the outers and PULL. With a bit of wiggling, the white plastic clips will pop through and latch.
From there, bit of spray on the outers, and they can be carefully pulled back into the car as far as they need to be.
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
