Diag software
I thought there was a new software PSA used for there 2019 + cars.
After a search on the web. i found a place where Diaxbox V9.91 can be bought.  and it seemes like this one is usable with the K9
Any thoughts?
I have bought the complete Diaxbog/lexia with cabel for the B9.
Would this cabel be usable for the K9
I posted a link to a free copy of the best version for vehicles after 2015 (same one you need, not particularly for the K9, there is no special one, sorry lol) and it works perfectly. It's the MrRorry version as a VM and is loaded to VMWare Player and used that way. Get it from the how-to section here. Diagbox V9.68
Unpack and add it to VMWare Player then say "I moved it" if it asks - a bit of Google will get you switched on to using the player.
Your cable will work fine. Hand it to the VM using the menu "Player > removable devices > Actia 100" (or what ever yours shows up as) and you are good to go. Set it to always hand that device to the VM and it will do it every time you use it.
Get V9.91 from eBay if you like but the one I posted will be better. It can also do coding of things like additive pumps etc where V9.91 probably won't. MrRorry is a legend in PSA software hacking.
Thank you. i need i to activate/deactivate systems in the car. boot autolock. seat belt chime and so on.m
Hmmm you may not be able to do any of that with any version of Diagbox, all personal configuration functions were moved online only in 2015 to dealerships and registered PSA workshops only.
The MrRorry version might work, I was able to code an additive pump, but other versions did not work for that on mine as it's 2017 model. Later ones are just the same. Never know though eh.
Try it and let us know how you get on.
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
