Threads: 2
Thanks Given: 5
Hi People
second post since joining, my first post was to say ello.
So where do you guys get your parts from ??? is there any know good stockists for the early Berlingo ???
when I can, I preferer new old stock (or in other words, original parts)
at the moment I only need a lambda Co2 censor, where would I start looking for one plz???
Thanks Received: 63 in 58 posts
Thanks Given: 2
10
Lately, eBay.
Lots of stuff via "parts in motion" for service parts - clutch, seals, cambelt, etc.
"carousel" for oils
And various other parts found via searching for the part number and sorting by price.
The following 1 user says Thank You to shtu for this post:1 user says Thank You to shtu for this post
• Urge38
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
21
I got my front discs/pads from Autodoc.
They were the cheapest around and a wide choice of bargain basement through to top notch gear but took Six Weeks to arrive from Germany.
Others have horror stories about them.
There's also a few clone sites with different logo but the same street address.
Bit of a gamble post brexit.
It's rear wheel bearings/discs/ pads/ calipers for me next so I think I'll play safe and go with one of the many local parts factors even if I have to cough up a bit more cash for my trouble.
• Urge38
Threads: 13
Thanks Received: 32 in 24 posts
Thanks Given: 8
10-10-2023, 03:02 AM
(This post was last modified: 10-10-2023, 03:06 AM by Kyleonsite.)
As above I buy from Autodoc due to being able to source OEM brands. I use the app and wait till the discount is 41% (seems to be the highest it goes).
I'm rebuilding an XC90 and have spent £2000+ on parts for it, no import duties or charges. Delivery is always consistent at 1 1/2weeks. When there have been a problem (Evri and a mislabeled component error from Lemforder) customer service had been great.
If you leave the £3.99 box ticked per order then you can return parts FOC for any reason.
Eurocarparts /Gsf etc don't come closer to availability and pricing.
However you do need to know who is OEM (Lemforder, Corteco, Elring, GKN Lobro, etc etc) as there a wide range of manufactures available.
The other downside is they use Evri for the UK side delivery - they are the worst courier ever, they will leave your parcel in a puddle in plain view with half of its contents missing.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4 208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
Threads: 39
Thanks Given: 1
4
I get a lot of stuff from my local Motor Factor
Peter
Threads: 67
Thanks Given: 237
50
^^^^ Ditto ........... and recommended
Serieal Berlingo owner
Threads: 10
Thanks Received: 27 in 26 posts
Thanks Given: 6
I like partsinmotion. I use them a lot on German stuff and their accuracy is brilliant. My experience is they're not so hot on French stuff (no hassle at all with returns, but if I need a part, I need it now rather than after the first return). I just use my local Parkers
https://www.thepartspeople.co.uk/#branches or the scrap yard.
Could be worse.... Could be a Caddy.
The following 1 user says Thank You to ItsGreen for this post:1 user says Thank You to ItsGreen for this post
• Urge38
