ABS problem
I have had the front drivers side hub off my sons 09 reg Berlingo to replace the bottom ball joint (we couldnt get it undone with the hub on the car.
After reassembly the ABS light has come on.  I understand about the sensor and have ordered a new one just in case but I am confused about the reluctor.  Is that fitted to the outside of the CV joint.  Thre appear to be 2 different types and I would like to have a replacement ready for when I start to strip it down again, just in case.  Can anyone give me the part number or even show me a photo please
Peter
Cat car any help? For B9 it’s a “antilock wheel radial target” No.5
As far as I know all the B9's used an ABS wheel bearing, the bearing has a built in magnetic tone wheel.
Yep as @jj9 says there's no reluctor ring any more, it's a magnetic bearing in the hub that's the target.
Pressed in with a 10 ton hydraulic press so not swappable at the kerbside.
Most car brands use these after 2010.
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
