Disable the ECO stop/start
Hi all, I have disabled the ECO stop/start system by using a discrete black rubber band around the ECO stop/start switch... Just remove some of the trimming around the switch, remove the switch, apply the rubber band and reassemble.
Until now the system has not complained that the switch is pressed at all times, so guess it will keep on working
And?
Why disable it and if you want to disable it, just do it in the menu settings?
I don't think I am able to disable via the menu system in my Berlingo 2016. The reason for disabling are too many short Stop/Start only saving a few seconds, which I think will wear out the starter and battery
On a stop start vehicle, the starter and battery are designed to take that use. What are you worried about, nothing I think.
Stop over thinking it.
You may be right, however my car already has got the battery, starter motor and Stop/Start module replaced at a cost of 1200 GBP (10.000 dkr), so I just wonder how much diesel I could have bought for that money, and how many other ressources have gone into this for saving a few liters of diesel during stop/Start
Ah ok yeah, I get it. It's something I've never wanted to have.
S&S starts the engine by the alternator. I still would not want it to fail, it's a pricey unit.
Ok, interesting, never heard about that before, but I can see you are right, it is called a reversible alternator. Don't know for sure if my blueHdi uses it, 2016, 99Hp
Oil sump design.
Today 09:38 PM
FUI: K9 tweeter
Today 09:13 PM
Which Lexia please
Last Post: Johnnyqg
Today 07:32 PM
Engine fault triangle when idle - solved
Last Post: MCRH
Today 04:23 PM
OBD Red discussion
Today 12:18 PM
» Replies: 47
Aftermarket horn help please
Last Post: Tuctuc
Today 11:37 AM
Rear sliding door jammed
Last Post: kratakule
Yesterday 07:50 PM
What is this?
Last Post: shawstvs1
Yesterday 06:38 PM
» Replies: 15
Timing chain/belt noise/issue
Last Post: Noiz_TnT
Yesterday 02:27 PM
And the lord said let there be....
Yesterday 05:56 AM
