New Driveshaft - which one?!
Hi everyone,
I have a berlingo M59 2008 XTR (ex forestry commission)
I think my driveshaft is knackered on the passenger side. I ordered a new one from BGA driveshafts and got the old one out no problem. I have replaced the old oil seal again no issues.
Before fitting the new one I compared the 2 shafts. The old shaft is shorter at the end that goes into the gearbox by about 10mm.
I sent pictures to BGA and their guys advised against fitting it as they said it might foul the inside of the gearbox if it went in too far and it also looks like it would only just sit into the oil seal.
The BGA guys couldn’t find a drive shaft that matched the measurements I sent them although I suspect they didn’t try too hard. I then called Citroen who gave me a part number but it seems similar to the new one I have.
I was wondering would the XTR have a specific drive shaft because of the gearbox/slip diff? And does anyone know the part number on anything helpful? Many thanks
Maybe ask the Forestry Commission if they had it modified?
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
They didn’t have them modified, but the xtr they had came with slip diff etc I believe, so I think they may have been slightly non standard when the forestry received these models.
Try putting your VIN in at CATCAR . . . (some work some don't)
If it works you should get the correct part number for the drive shaft you need, you could have been given the wrong number from the Citroen dealer.
A long shot, but is it 4WD? A French company coverts Berlingos to 4WD under contract; search this forum for Dangel (and Google for general info on them). I'd imagine it's a similar process to WAV conversions, where a company converts new stock vehicles.
53 1.4i MS MPV RIP
08 C4GP 1.9 VTR+
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
