  • 19 Vote(s) - 2.63 Average
Is this the fuel pump?
Just trying to find out if I'm lucky enough to run on rapeseed oil!
It says Pierburg which sounds familiar but I thought Bosch or Lucas were the likely manufacturers of Berlingo fuel pumps...
[Image: IMG_0119.jpg]
Correct me if I am wrong but is that not the vacuum pump for the braking system you have photographed there???
Doh! Thanks andy. It's to the right of the cylinder head as you look into the engine bay from the front, by the fuel filter so I took a guess while I had the bonnet open to check oil.
Diesel fuel injection pump is located at opposite side of the engine (LHS) and slightly below cylinder head level.
Follow the metal pipes back from the injectors and thes lead to the pump. Usually a small tag or label on pump with manufacturers name etc and usually Siemens or Bosch..
  • chronyx
Many thanks Mr womble Big Grin
Today 05:46 PM
Today 05:17 PM
Potential Purchase!
Today 03:03 PM
Last Post: DannyWxM
Today 12:55 PM
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
