  • 21 Vote(s) - 2.76 Average
berlingo 1.9 diesel knock advanced
hello to everybody on the forum ,i recently bought a 2002 berlingo 1.9d and had a problem with the electronic advance on the injector pump ,came out in the morning started up,and the engine sounded harsh and rattley ,like diesel knock when the pump timing is too advanced ,turned out to be the no 4 injector that has a sensor with a wire coming off ,changed that and now its running fine again Smile just thought i would share this info as it might help someone with similar problem
[-] The following 2 users say Thank You to phil725 for this post:
  • adam3rdcanvey, andy-womble
Thanks Phil.
All feedback and info is appreciated..
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
