Injector Replacement
The pain and skinned knuckles of the clutch replacement (almost) behind me, and it's time to start gathering parts for replacing all 4 injectors.
Parts\tools thought of so far,
- Exchange injectors. (£300ish)
- Injector seal puller (£15)
- Injector seat cutter (£20)
- Copper seals (free with injectors)
- Leakoff seals (free with injectors)
These don't seem to have a bad reputation for stuck injectors, I already have big screwdrivers and crowbars, so I'm not planning to buy a puller.
Other things,
Clamp Bolts - these seem to have a single E-torx bolt per injector, part 1982.G5. £10ish a set of 4.
Clamps - I can't see a need to replace the hold-down clamps.
Plastic guide thingys - seem to be part number 1982.G6
Rubber seals in head - I can't work out of this engine - 9HL (DV6C) code - also has the rubber seals that seat into the head.
Catcar is not being very helpful here, best I can find is this page which doesn't specify engine code. http://www.catcar.info/citroen/?lang=en&...aWVyPT0%3D
Anyone got any ideas on,
- The correct plastic guides?
- Do I need rubber seals into the head?
Thanks in advance.
The injector is a ease to remove. Have done 8 of them now
Loosen the returnline, 2 etorx, and diesel pipe.
I used a screw driver/ small crow bar to get them out. If they are a little stuck. use the closed end of a spanner on the diesel pipe stud to wiggle them loose.
For the seals use a pointy metal pick or simular to get them out.
The copper washer in the botom i used a phillips screwdriver that was a little bit bigger than the senter hole, and pressed it down.
I had a problem with remowing two of the Torx studs for the hold down clamps. i end up with removing the engine cover, and used a chissel to whack them loose.
If you send me your VIN i can send you the parts list for the things you need.
[-] The following 1 user says Thank You to Tikki for this post:
  • shtu
Thumbs Up
Appreciated, I'll send it over.
Incidentally, I've found 7zap to be much easier for drilling into specific models\variants than catcar,
https://7zap.com/en/catalog/cars/Citroen/BERLINGO/
Good luck with 7zap, there's a reason we don't use or recommend it.
PSA diesel engines all show "spark plugs" and "coil packs" but no diesel injectors, and the sections for exhaust line (emissions) should be cat & DPF but instead only shows "secondary air pump" which they don't have, and when you drill into that section, it's actually a blow-up of a gearbox.
Not much use.
I'm having more luck than that, https://7zap.com/en/catalog/cars/Citroen...+INJECTOR/
That shows partial obscured part numbers and says "only premium users can see applicability" - £59 a year or something it says.
Why not just get ServiceBox off eBay if you want to pay anything (less than £20) and then you have the official part numbers and all repair procedures as well as electrical schematics.
Catcar is free and for most folk is fine if they bother to search properly. If anyone prefers 7Zap then no worries either way.
Ahh, click through to the search and you can see the numbers anyway. Smile
I just found it easier to find the right variant on there (of which there are SO MANY)
[-] The following 1 user says Thank You to shtu for this post:
  • Sol
How much adblue and where is it best to buy it
Last Post: dickl
Today 09:25 AM
Any opinions on Eolys .
Last Post: Pepito
Today 02:54 AM
OBD Red discussion
Last Post: Pepito
Today 02:50 AM
» Replies: 28
Top clock screen upgrade.
Yesterday 07:23 PM
And the lord said let there be....
Last Post: Sol
Yesterday 08:23 AM
Headlight adjustments
Last Post: Sol
Yesterday 08:08 AM
Berlingo reverse light cable.
01-12-2023 09:44 PM
Heating
Last Post: Sol
01-12-2023 07:16 AM
New flywheel and clutch now throttle pedal perce...
Last Post: Sol
01-12-2023 07:12 AM
9" multimedia player for the B9
30-11-2023 09:20 PM
