Knocking noise and feeling through steering wheel
Not going so well with the new purchase lol, the vans now developed a knocking noise and feeling through the steering wheel. More noticeable when moving away or slowing down. Doesn't really do it when turning, or I've not noticed. It's like a clunk, clunk not overly loud. But definitely a new sound. Any ideas? It's at the garage 3rd of November for the timing belt and water pump etc.
Strut tops? CV joint? That's what I'd look at first.
It's the sort of thing that can only really be diagnosed in person with a big crowbar. Smile
A "clunk" on moving away AND when slowing down, is more likely to be the lower arms' rear bush, what you would call the wishbone.
Also I'd do them as a pair along with the drop links, fitting complete arms and not messing with trying to fit a new bush. As the ball joints are also likely to be worn out on the lower arms too.
My lower arm rear bush on the drivers side was picked up back in July in the MOT and now has started to clunk, exactly as you describe.
I've had this loads of times on older cars. It's that bush, 100%. Very noticeable on hitting a ridge pulling into your driveway or over a speed bump.
(24-10-2023, 06:50 PM)hofhomer Wrote:  Not going so well with the new purchase lol, the vans now developed a knocking noise and feeling through the steering wheel. More noticeable when moving away or slowing down. Doesn't really do it when turning, or I've not noticed. It's like a clunk, clunk not overly loud. But definitely a new sound. Any ideas? It's at the garage 3rd of November for the timing belt and water pump etc.
Possible problems for what you're describing include...
Engine Mounts
Strut top bearing mounts
or the very common [and cheap and easy to replace] drop links on the front suspension.
Of course it may not be any of these, other problems are available on Citroens  Wink
(24-10-2023, 07:42 PM)Zion Wrote:  A "clunk" on moving away AND when slowing down, is more likely to be the lower arms' rear bush, what you would call the wishbone.
Thanks, I'll suggest this to the mechanic.
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
