what clutch make
Afternoon all
i recently bought my first B9 Berlingo van, 75hp, the clutch bite point is quite high up but no slippage or bearing issues and is easy to change gear. it suggests that it is worn so was looking at clutch kits and the vast difference in price of them. Ive always used LUK in the past. Is it worth saving money and getting a deferent make one, what do people recommend from past experience?
thanks in advance
My son recently had a new clutch fitted to his 09 B9 Berlingo. Thye fitted a DElphi clutch - original equipment
Peter
What sort of price was that for fitting and parts Pete? I'm in the same boat, although won't replace it until it's just about dead.
I've just fitted a LUK one to mine, was under £100 for a 3-piece kit, cheap enough that I wouldn't go cheaper. £80 flywheel skim on top of that as it had a couple of heat spots.
Other parts I fitted at the same time, partly required, partly as it was apart anyway and sod taking the 'box out twice for the sake of a £15 oil seal.
Crank seal (Febi)
Guide Tube \ Input shaft seal (Febi)
Output shaft seals (Febi)
Clutch Fork (Blue Print)
Clutch fork bearing (OEM - the blueprint fork comes with one, I swapped it for the OEM one)
Fork Pin (OEM)
Listings I bought from, handy for part numbers if nothing else, obviously check your own details to ensure you buy the parts you need,
https://www.ebay.co.uk/itm/234418775028 clutch
https://www.ebay.co.uk/itm/235158461486 crank seal
https://www.ebay.co.uk/itm/234862008723 diff seals
https://www.ebay.co.uk/itm/334878849361 guide tube\input seal
https://www.ebay.co.uk/itm/235147000611 clutch fork
https://www.ebay.co.uk/itm/155788408007 clutch fork bearing
https://www.ebay.co.uk/itm/401781166714 fork ball joint
How many hours labour did you put in @shtu - and be honest, was it a week?
My clutch was done at a trusted garage which is a Bosch service centre and it was £1400.
It's ok saying under £100 for a clutch kit (bargain basement clutch) and then a list of parts after that, but how much in parts and potential labour would it have been - as its misleading to say "I got a clutch kit for £100" as most users would not be doing it themselves, if they had a life.
Then a list of additional parts as long as your arm afterwards...
I'd guess that £1400 is about 8-10 hours labour plus parts.
I'm well known for not having a life. Big Grin 20ish hours, a few of thiose wasted by not having a workshop manual and working single-handed off the floor. There's plenty posts on here from me saying what a monumental ballache the job's been.
Point I was making was "A decent one is £100, isn't that cheap enough?". It's also not a big propotion of the cost if you're paying someone else to do it.
It's a not-unreasonable list of what parts I needed, and what could be considered when the job is being done - The crank seal is a £15 part, guide tube about a tenner, fork about the same. Frankly you'd be daft not to change them while the gearbox is out. Or you're risking paying £1400, twice.
What's the problem with quoting parts prices? Like all these folk did https://www.berlingoforum.com/thread-15158.html
[-] The following 1 user says Thank You to shtu for this post:
  • swawp
Ah no I agree totally with you, but most folk wouldn't be able to do the job or if they could, they can't put 20 hours into it so they face paying the big bill.
If someone says their clutch is on the way out, and they think "ok £100 or so, sounds not bad", then get a garage quote of £1400 they would fall over.
Better to be realistic and tell both sides or both options, then people are better informed on what to expect, especially new users. Folk will latch onto the £100 message and only hear that first.
That's what I meant. Big Grin
Ahh. I think even the old Cavaliers and Astras that could have a clutch swap without removing the box were more than that. In 1985. Big Grin
The place I had the flywheel machined had one in recently for the same job, and even with a lift, a full workshop, and a bloke referred to as "the van master" they were still swearing about it. It's not a cheap job, at least partly because it's such an industrial-strength ballache.
My DIY efforts are about £200 deep in parts.
Top tip for the OP - all the major manufacturers have technical support - use it to get the correct fitment. The parts factors were wrong on the correct one for mine.
LUK replied to email within a few hours, as did Sachs.
thanks for all the replies, after having a look around most of the makes are there or there abouts the same cost, il stick to what i know LUK has always been ok. Shtu your list of parts is comprehensive, thankyou
(30-10-2023, 11:35 AM)swawp Wrote:  Shtu your list of parts is comprehensive, thankyou
Most of those parts will suit almost anything, but check against your own specific car. In particular, factors couldn't get the clutch fitment correct even when given chassis numbers and engine codes. The tech support email contacts could.
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
