Threads: 67
Thanks Given: 238
50
New injector question for an 07 1.6 Hdi 90
If I fit a new injector will it need coding ?
How much are injectors ?
Serieal Berlingo owner
Thanks Received: 15 in 15 posts
Thanks Given: 1
No, coding is nonsense. The adaptation process takes place while driving under load. ~200 a pop.
The following 1 user says Thank You to SinsBird for this post:1 user says Thank You to SinsBird for this post
• geoff
Threads: 67
Thanks Given: 238
50
Phew, thanks !
Hoping I'll not need one done.
Will buy an eBay leak off kit shortly, just gotta choose one.
Threads: 10
Thanks Received: 27 in 26 posts
Thanks Given: 6
Don't go mad with your spending, any will do - I used some bits of clear pipe and a few old coke bottles for years, If an injector's trickling diesel back, it's alright. If it looks like it's going to fill the bottle before you finish your brew,, or is just faster than the others, it's not good.
Could be worse.... Could be a Caddy.
Threads: 67
Thanks Given: 238
50
Thanks, funnily enough just bought from eBay @ £28 delivered.
Also bought a new leak off pipe @ £10 just in case of mishap as I don't need the vehicle lying idle waiting for bits.
After delivery I'll just need a dry day coupled with some motoivation.
