INTERIOR LED STROBE
I bought some LED 501 bulbs from Halfrauds and replaced the 3 that are in the front interior light, with the engine on they are fine but after around 5 seconds after turning the engine off the middle one starts to strobe. the 2 map light ones are ok as they dont work with out the engine running, does the car reduce the supply voltage to the lights after the ngine is switched off? can these be replaced or are we stuck with the yellow light from the original bulbs?
Thanks for any help
Yep, the eco mode kicks in and cuts the power to the inside and the BSI starts to check what is going on with the weird bulb readings from the LEDs, then they won't go off. The interior light circuit drops to 8v when not running and the eco mode is active.
All lighting is powered from the BSI itself, not a switch or a fuse. The switches just signal the BSI that you want the lights on. LEDs can be a problem in these vehicles.
[-] The following 2 users say Thank You to Sol for this post:
  • H2Sparks, swawp
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
