Electronic brakes and icarsoft pro
I am trying to change rear brakes on my k9.
I have icarsoft pro and downloaded the latest version v31.80
But I can't find the k9 in the list, and the diagtester don't recognize the car with the bin number.
What to do?
I work on my rear brakes, on 2018 K9, without any of that computer mumbo-jumbo. Release park brake, remove handbrake actuator, work on brakes as normal, adjust calliper, replace handbrake actuator, job done.
Geoff
(03-11-2023, 05:27 PM)Tikki Wrote:  I am trying to change rear brakes on my k9.
So it just has Citroen software installed?
If you email them they are pretty quick to reply or do as above. On my Caddy have the option to turn off automatic parking brake although I didn't notice till I'd done the job.
Free-wheeling
In certain situations, you must allow the vehicle
to free-wheel (while being towed, on a rolling
road, in an automatic car wash, or being
transported by rail or sea freight, etc.). 7
The procedure varies according to the type of
gearbox and parking brake.
With a manual gearbox and
electric parking brake
Release procedure
► With the engine running and while depressing
the brake pedal, move the gear selector to the
neutral position.
► While depressing the brake pedal, switch off
the ignition.
► Release the brake pedal, then switch on the
ignition again.
► While depressing the brake pedal, press the
control lever to release the parking brake.
► Release the brake pedal, then switch off the
ignition.
Reverting to normal operation
► While depressing the brake pedal, start the
engine.
[-] The following 1 user says Thank You to 5EAN for this post:
  • brodfather11
Diagbox 7.57 download
Today 09:13 PM
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
