[Warning Light] Electic issues berlingo 1.4i
Hi all.
Just bought a berlingo 1.4 petrol but ran in some trouble this weekend.
Picked the car up last friday and the half hour drive home was troubleless.
When i wanted to start the car saterday it had a flat battery. Replaced it with anouther one and it started again.
Then changed the speedo sensor, which didn't solve the dead speedo, and washed the car.
Sunday morning, the car started fine but within a few meter all the lights en dials started flashing and moving and the wipers came on. Shut the car off and it wouldn't restart. Charged the battery again and same thing happend.
Asked some friends that are mechanics who pointed to a bad earth or overcharging altenator. Is this a berlingo thing or am I just unlucky
It could be a bad earth cable or connection, as it works and then doesn't. Time to properly check the ends of all heavy cables between the battery and body, battery and engine, body and engine. Anything loose or corroded should be fixed before anything else.
Check the main bolted connections on top of the fusebox in the engine bay too.
Slack connection is most likely the problem. Check the simple stuff, don't over think it.
And check all bolted fuse connections on the battery cover fuse "panel" are tight enough. (Don't go nuts with spanner here though, just tight enough ok - copper and brass is easily damaged.)
I have had similar issues with my Berlingo. It very much sounds like bad earth(s). Unbolt them, wire brush the bolt(s)/terminals and chase the threads of the mounting points with an appropriately sized tap, then bolt back up again. Let us know how it goes
Sent from my Pixel 6a using Tapatalk
The berlingo is back. A broken wire from the alternator was the cause. So now I can start my Berlingo life
Rear brake caliper piston problem
Yesterday 08:47 PM
Cruise control retrofit
Last Post: E30alex
12-02-2025 08:39 PM
Part ID, what's this for?
Last Post: Muppets on Mars
12-02-2025 12:19 PM
Alloy wheels
12-02-2025 08:05 AM
2011 B9 DPF warning light
11-02-2025 07:13 PM
» Replies: 15
Greetings from Romania
11-02-2025 10:43 AM
Whats Your Berlingo 'Pet' Name.
Last Post: Lokusan
09-02-2025 08:17 PM
» Replies: 32
Indicator/lights Stalk
09-02-2025 06:26 PM
Roof bars and roof box
Last Post: LukeClark
08-02-2025 07:24 PM
Remove Wing
Last Post: ADarkDividedGem
06-02-2025 02:13 PM
