Brightest legal main beams for gen 3 Multispace?
I have a 2019 Berlingo Multispace, current shape. I drive a lot on dark country roads, and could do with better main beams. It currently has Philips X-Treme Vision 150 H1s fitted, but they're not as bright as the Xenon mains fitted as standard to my 2010 Volvo C70. I suspect the problem might be the actual glass enclosure on the Berlingo. Any recommendations for road legal brighter main beams bulbs?
There's another thread that recommends the Osram nightbreaker range but be aware that are a number of versions [you want the brightest one] All the ones listed are UK legal.
Note that a post in the thread below (from overseas) mentions 'legal' LEDs, these are not legal for the Berlingo in the UK
https://www.berlingoforum.com/thread-213...ghtbreaker
[-] The following 1 user says Thank You to Multispacer for this post:
  • sonneur
There are also third-party wire looms available.
On my old M49 I had one that was made up of thicker wire and some relays.
Wires hooked directly to the battery, there was a H4 bulb-shaped connector you plugged into the regular connector behind a headlight, and two new headlight connectors.
Because the wire was thicker, and went directly to the lights(just passing through the relays also mounted in the engine compartment) you had less of a voltage loss than with the regular wiring. And yeah, it made a visible difference with H4 bulbs.
[-] The following 1 user says Thank You to Gadgetman for this post:
  • sonneur
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
