Threads: 5
Thanks Given: 6
Hi guys,
I have noticed whilst driving that it sounds like my exhaust is blowing as it sounds really deep and throaty inside the car, but outside the car it sounds normal, i hear it in all gears apart from when she is cruising in gear 5, it almost sounds like i have a cherry bomb fitted to the exhaust, but all the sound is on the inside.....its a wierd one.
Any help/knowledge would be greatly appreciated.
Cheers!!
Threads: 9
Thanks Received: 31 in 26 posts
Thanks Given: 8
Think I saw someone else mention on here that the exhausts on 2003/4ish models and earlier may be reaching the end of their natural lives in many cases about now. I recently had to have mine replaced (53 plate). Similar noises to those you describe, then it separated completely/broke, from corrosion at the joint just to the front of the back box :-(
Not sure what to suggest except have a bit of a poke around underneath...
Threads: 51
Thanks Given: 23
03-04-2012, 01:23 PM
(This post was last modified: 03-04-2012, 01:25 PM by crickleymal.)
I thought my exhaust was blowing but I couldn't see where from and it was getting louder. A sort of throaty growl. It was really puzzling me then last night I lifted up the bonnet and whilst the engine was running I peered around. By chance I pit my hand on the air intake pipe leading from the grill to the air filter and hey presto no noise. To make it a more permanent fix I got a surgical glove and cut off the wrist bit. Slid that over one pipe then reassembled.
Threads: 5
Thanks Given: 6
I can only hear the noise inside the vehicle not outside, sounds like a cherry bomb inside the car, its wierd!!
Threads: 5
Thanks Given: 6
Strange think i better get it checked out!!
Threads: 5
Thanks Given: 6
Took the wife to work this morning and the noise was so loud i could barely hear the radio...blimey!!
Threads: 9
Thanks Received: 18 in 15 posts
Thanks Given: 21
(04-04-2012, 06:54 AM)stedjx Wrote: Took the wife to work this morning and the noise was so loud i could barely hear the radio...blimey!!
Thought you were going to say you could barely hear the wife talking, if so I was going get one of those exhausts :lol::lol:
2011 (61) Multispace XTR 110 in Kyanos Blue
Threads: 5
Thanks Given: 6
SORTED, had a new clamp and paste around the middle section and adjusted the back box which had come off one of the rubbers, sounds fine now!!
