Air bag warning light
My K9 air bag light occassionally shows on start up but always disappears after a mile or two. My first thought was to open and spray the connections under the front seats with switch cleaner but I'm not sure how to separate the big yellow plugs. Has anybody successfully disconnected these plugs? How do the separate? Thanks
After examining the plug closely and looking online I can answer my own question for the benefit of others. The photo illustrates the two halves of the plug; the lever can be moved after pressing the small tag. The action of the lever is to move the two halves apart (or closer in the other direction). Cycling the lever without separating the two halves has the effect of rubbing the electrical terminals together helping their continuity.  If there is a poor contact here this may help.
[-] The following 1 user says Thank You to Cumbrian for this post:
  • brodfather11
triangle light
Last Post: norm1
Yesterday 08:55 AM
Yesterday 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
