Threads: 3
when i am turning right and i turn on my indicator more times than not it also puts on my headlights.this can happen wheather i have my lights on or not
any ideas on what the problem could be
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 166
21
Take your boxing gloves off when driving!
• andy-womble
Threads: 32
Thanks Given: 24
Likely to be your Com 2000 unit. This is the "switch" assembly on the end of the indicator stalk around the steering column.
Threads: 3
the horn isnt working either would this be connected
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
Mine does the same but it puts main beam on, sometimes it does it a lot then it stops for a bit , the last time mine did it was two months ago and I don't fancy paying out for a new unit
Threads: 2
Thanks Received: 7 in 3 posts
Mine has just started doing similar things too and apparently it's the Comm 2000 Unit that's at fault.
Specific problems that I have:
- When unlock the car and open the driver door the lights on warning beep sounds even though lights are off (stops beeping when the door is closed).
- When turn ignition on the headlights come on.
- When indicating right the indicator flashes 4 times then stops, and the headlights come on if not already on.
The most annoying problem is the indicator not working properly but it works fine if I switch sidelights or headlights on so I've just been switching lights on as soon as I get in the car.
I've been quoted £220 to get the Comm 2000 Unit replaced, which I will do eventually, but I'm in no hurry since the problems are not showstoppers.
Cheers,
Alan
