Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
My doors feel as if there is grit in the runners, what do people recommend for cleaning the tracks and keeping the doors running smoothly please?
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 75
Thanks Given: 223
164
Cans of compressed air for computer air-dusting would work to blast the grit out first, then lube as advised above by @
Multispacer. You can get those online easily.
• Matt Haigh
Threads: 67
Thanks Given: 237
50
My sliding doors get in a heck of a state mostly down to my dogs being on and off the beach - they jump in and out and the sand gets in everywhere.
The doors are hard to get moving / close from the fully open position and rumble like the devil as they slide both ways.
I use a garden hose with the trigger gun set to " jet " to direct water into and along both top and bottom rails ( dooors open whilst doing so ! ) and work the doors open and shut whilst washing the gubbings out
This does the trick for me
Once washed out it is best to lube everything if you can
I buy WD40 liquid by the gallon ( I have lots of other uses / hobbies ) and using a hand squirter much like a kitchen cleaner bottle give the gubins a good sluicing with the stuff, does the job.
Otherwise use an aerosol oil spray or a spray grease - as said Lidl etc often have decent stuff at agreeable prices
Serieal Berlingo owner
• Matt Haigh
