Hi guys,
I have an 07 Berlingo and the rear door handle suddenly stopped opening the door. Now, it does open from the inside so I'm presuming it's something to do with the handle mechanism.
I'm not a mechanic by any means so if someone that has maybe had past experience with this issue could give me some tips it would be greatly appreciated.
Thanks in advance. Stefan.
Threads: 10
Thanks Received: 27 in 26 posts
Thanks Given: 6
Is it a hatch or double doors? I've had bother with the hatch on mine not unlocking, particularly if I locked it with the remote. On inspection, the actuator was pulling the lock, but the mechanism was a bit sticky, so it wasn't unlocking properly. unless I helped it a little. I took the inner trim panel off the door, gave it a blast with the air duster and covered the mechanism in spray grease. Seems to be working ok so far.
Could be worse.... Could be a Caddy.
Threads: 42
Thanks Received: 409 in 366 posts
Thanks Given: 137
31
The earlier models had a habit of the wire (not electric ) slipping out of the plastic clip which connected the handle to the mechanism. It would not open from the outside but would from the inside , maybe something like that has happened to yours?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
