M59 DV6ATED 1.6 HDi Coolant leak - presumed to be from the oil cooler.
Driving along at near midnight the cab heater lost temperature and the needle on temp gauge went down a third.
From this I knew there was a coolant leak so not wanting a head gasket failure I stopped straight away to check and found the expansion tank empty, and had to fill up using a carrier bag dipped into a ditch with running water. This got me home eventually.
With the engine running a quick look shows water dripping down from the front of the engine and onto the hydraulic cylinder directly below the oil cooler.
It looks like the oil cooler and its seals are going to be the culprit...... well I hope so as this looks nice and easy to sort out Lol !!
Time to spend money
CatCar is useful once again as it gives good images to study together with relevent part numbers.
From their diagram it seems a leak could be occuring from where the oil cooler is bolted against the oil filter housing.
Ebay sells everything it seems
Cooler and seals ( 1103K2 ) @ £29
Filter housing ( 1103N9 ) @ £36
Combined unit ( listed under 1103N9 ) @ £ 51
Before I order will have another look in the morning - bit like cutting wood, measure twice and cut once.
Comments and advice welcomed.
Time to spend money
Serieal Berlingo owner
